CUTTING HULL FLOOD / VENT HOLES
  • insvorloc
    • Jan 2012
    • 1
    Shipmates: I am about to start on an ENGEL GATO build, and need some tips / tricks / tools / advice / magic / witchcraft
    for cutting / drilling the thousands of holes on this hull. Any and all advice is welcome. Any build advice specific to this
    sub kit is welcome also. Thank you in advance.
    Re: CUTTING HULL FLOOD / VENT HOLES
    Good tools to do the job right are a must.
    I would start a collection of Perma-grit tools.
    They will not dull when working with fiberglass.
    Then a good rotory tool like the Dremil Stylus.
    The best tool I own for modeling.
    http://www.dremel.com/en-us/tools/Pages ... x?pid=1100
    I can't say enough good things about it.
    Get some good carbide burrs too.
    Fiberglass is death to all tools not made from carbide. BD.
      I find diamond coated tools are good for working glass laminates.
      I have a miniature set of diamond needle files, and they're fabulous for working GRP.
        A technique that I have helpful when making any sort of opening in a fiberglass hull is to cover the general area to be cut with tape (clear or blue masking, etc.). This will prevent most of the edge chipping that occurs.
        I also draw all the openings on the hull, assuming that there aren't pre-scribed lines, to act as guidance while cutting. I cover those markings with clear tape which prevents the lines from getting erased as you work on the piece. If I use an opaque tape, I draw the guides directly on the tape.
