Question:O ring Sizes
  • jack b
    • 45
    So I was wondering how to measure the O rings?
    do you just lay one out and measure it or is there some special way
    I have a 3 " tube and need to find a supply of O rings
    Any help?
    JAck B
    Re: Question:O ring Sizes
    Jack,
    O-rings are usually measured by their ID and width (of the material itself)....meaning that the OD would equal the ID + twice the width.
    If you would like to understand how to select the correct size o-ring for a given application, check out this excellent document from Parker Hannifin:
    http://www.parker.com/literature/ORD%20 ... ndbook.pdf
    ...more than we'll ever need to know about o-rings!
    • jack b
      • 45
      Thanks for the 292 pg PDF Catalogue
      Now if I have a spare month to read it
      No, really thanks!!
      I will give it a look
      Jack B
        It is a big document. Ignore most of it..just focus on the size determination parts.
        • jack b
          • 45
          Looks like it has some good info
          I will
          Jack B
