Shaft and Push Rod Seals
  • Rogue Sub
    • Jul 2006
    • 1724
    Has anyone ever made a post on how to make your own seals? If so where. If not. We should make one!!! Help anyone.
  • Rogue Sub
    • Jul 2006
    • 1724
    Nobody out there wants to
    Nobody out there wants to share the knowledge?????
    • pirate
      • 849
      Dave Merriman makes them himself.
      Dave Merriman makes them himself. I think there's a post about it on CASWELL's site, or in the Cabal, on SubPirates, he shows how to do it.
      • tmsmalley
        • 2376
        Seals are so inexpensive, most
        Seals are so inexpensive, most of us just buy them from Mike's SubWorks or Caswell and save our free modeling time for hulls, WTCs etc.
        • pirate
          • 849
          Tim,
          I just noticed something. God
          Tim,
          I just noticed something. God forbid someone might think you were from North St. Paul, Minnesota. Everyone knows the only place to be, or be seen, is South St. Paul, Minnesota.
          • tmsmalley
            • 2376
            There is a St. Paul,
            There is a St. Paul, North St. Paul and South St. Paul. Suburbs of St. Paul, and all with separate zip codes.
              Sorry to seem to be
              Sorry to seem to be not very helpful but this has been covered many times before.
              Have you tried searching the threads?
              Let us know how you get on.
              Davy
                I just make my own
                I just make my own shaft seals and stuffing boxes from K and S tubbing and an asortment of automotive O rings,oilite bushings and precition ground stainless steel shafts.Even hydraulic masts are costom made this way.
                Total cost for a ft about 6.00 bucks ,stuffingbox seals all ready to go with marine grease.
                Make your own that way you learn how its made and save a buck to put into the next project.To this day I have never had my own shaft seal leak The same goes for servo rods,but I like bellows beter and those I cant make.
                Thanks Dave
                • kazzer
                  Banned
                  • Oct 2006
                  • 324
                  These things certainly aren't worth
                  These things certainly aren't worth the trouble to make, especially as they are a critical part of your cylinder. Screw it up and down you go!
                  Let D&E Miniatures do it, and order them here.
                  David is also gradually phasing out the 1/8" seals on all his Sub-drivers, to use 1/16". They have less drag, and can use smaller servos.
                  see those here]http://www.caswellplating.com/models/transmitter.html[/url]
                  Caswell Pack of 4 = $8.00
                  Mikes Sub Works pack of 4 = $16.00
                  • Rogue Sub
                    • Jul 2006
                    • 1724
                    Yes mike does double the
                    Yes mike does double the price on evrything
