Weathering
  • Rogue Sub
    • 1724
    Weathering
    Anyone know a good resource for learning how to do weathering or is it mostly just trial and error?
    • 1325
    David Merriman has a tape
    David Merriman has a tape set that describes his techniques...well worth owning. Contact David through his website...
    www.vabiz.com/D&E
    reason for edit: fixed URL
    • Rogue Sub
      • 1724
      Thank you but the link
      Thank you but the link wont work just takes me to a search engine.
      David are you out there!
      • aeroengineer1
        • May 2005
        • 241
        That link should have been
        That link should have been www.vabiz.com/d&e
        Adam
          • 1325
          yep... i fat fingered it...and
          yep... i fat fingered it...and fixed it in my original.. apologies...
            • 342
            Plastic modelers are good at
            Plastic modelers are good at weathering. Check out Fine Scale Modeler & its publisher, Kalmbach Publishing has books on detailing & weathering.
            • cyclops2
              • Mar 2006
              • 23
              I have only weathered 1
              I have only weathered 1 model to try it out. I put a clear satin clear coat over the entire model. After 4 days of drying, I started the water colors applied from a fine tipped syringe. I dripped the color faster and wider if i needed a large rust pattern. It is actually fairly easy. Plus you can remove all, most, of any mistake right away with water and a rag. When dry I recoated with the clear coat again.
              Looks great 5 years old.
              • pier 72
                • Jun 2007
                • 140
                Guys, guys, guys, if it's
                Guys, guys, guys, if it's rusting you're after why simulate it when you can use the real thing?
                For years now, I've been using my own method of applying REAL RUST onto enamel painted hulls without the need to over-coat with varnish.
                Years ago, under my old kitchen sink I found an old, brown and powdery steel wool pad and immediately knew what to do with it. I mixed a quantity of the rust powder with water (and later with a tiny bit of dish washing detergent) then brushed it directly onto the hull of my model. I let it air dry then lightly brushed away any excess. A couple of applications may be required to get the effect you're after. Purely by accident I discovered that it permanently stained enamel and didn't wash off during sailing, i.e. no need to over-coat. Model Boats magazine published my method last year but you can have a look at it in my "Hints...." page at www.pier72.com
                Trust me, it works!!!
                • pier 72
                  • Jun 2007
                  • 140
                  And here's my completed Revel
                  And here's my completed Revel Gato, USS Flasher using my "Real Rust" method. It doesn't wash off during sailing........
                  The only place I used a clear, Matt coat was over the decals. Some of the rust even stains those areas.
                  Wait until I start weathering my next project, a British T-Class Sub!!!!!
                  NOw that's going to be RUSTY!!!!
                    I'm by far no modeler,
                    I'm by far no modeler, but a simple method that I found to apply some weathered effects were to simply place some paint thinner in a cup and add some of Testors Rust color modelling paint little by little to the thinner until you reach the consistency you prefer, the application can be attained in a number of ways, eg, eye dropper, Q-tips, etc. I've recently weathered my Revell Gato by darkening the light colored areas and by adding some rust as mentioned. I know it's not Museum quality by no stretch but good enough for my standards. Al,
                      AL
                      your boat looks great to
                      AL
                      your boat looks great to me and your standards have always impressed me.I will be weathering soon my XXI and I hope it comes out as nice as yours with patience Im sure it will. Great job!I want to see her at the lake soon .
                      Dave
                      • pier 72
                        • Jun 2007
                        • 140
                        That does look good.
                        I'm trying
                        I'm trying something else now, other than my rusty steel wool method.
                        I've got some of the stuff below.
                        To get this nice effect...
                        Dave
                        • pirate
                          • 849
                          How's this for a weathering
                          How's this for a weathering tip Kevin:
                          • Paint the sucker
                          • Leave it outside in the rain, sun, heat and cold.
                          • Bring it in and coat over all the dirt and crap with clearcoat.
                          There you go—weathered.
                          • boss subfixer
                            • Aug 2004
                            • 656
                            Pete lets not forget the
                            Pete lets not forget the bird droppings!
                            • Rogue Sub
                              • 1724
                              HAr har Pete,
                              The funny part
                              HAr har Pete,
                              The funny part is I no longer clean my boats when i run them. My akula is developing a nice bit of nastiness on it that i think i will clear coat over soon
