another way to shape a master
    I am scratchbuilding a submarine and came across the following tip,
    which was already used in anger by a few of my fellow modellers in
    the SubComNL.
    The normal way to make a master form is to cut out ribs and fill the
    space between the ribs with some foam plates. you can see a splendid
    example of this construction method at mylo's building thread
    With me, the scaled down version of the drawings gave a space between ribs
    that will not ever be produced.
    So, I used a bottle of sprayable urethane foam (called PUR over here).
    It is often used in construction, as a glue and as a filler. (H*ck, half my
    house would not be standing if not for that foam. What happened to
    wood and nails and craftmanship ?)
    The beauty of this is that it glues together your frame and it will fill
    any size of space.
    I just made a test-setup of two ribs of 1cm MDF, spaced apart with an
    M5 threaded rod. Then, to counter the foam's expansion (and thus to
    get smaller air pockets) I wrapped it with cling-wrap household foil.
    This foil does not stick to urethane, nor to polyester.
    then I stuck the nozzle of the spray can thru the cling-wrap and presto ]http://home.vianetworks.nl/~raalst/cb/proef2.jpg[/img]
    after hardening and sanding, it looks like this ]http://home.vianetworks.nl/~raalst/cb/fillspant.jpg[/img]
    urethane is polyester resistant, but I intend to apply a layer of car filler
    to be able to sand the whole thing smooth(-er than the ribs are currently)
    Ps building thread will follow later.
    I'll add a further piece
    I'll add a further piece of advice- before applying polyester filler apply a piece or two of chooped strand matt and resin. This will skin the master with a tough surface that resists any handling damage.
    Then just fill as normal.
