U-47 - Grease
  • lbgolon91
    • Jul 2004
    • 11
    U-47 - Grease
    What type of grease do I use for pumping into the drive shafts? Brand name, can it be bought locally or is it a specialty item? Please help.....Thanks, Larry G.
    Well I use a silicone
    Well I use a silicone grease for lubricating my shafts. This is water proof, and doesn't attack the rubber.
    I favour the Servisol brand- good quality and readily available in the UK- however I don't know if it's as easy to obtain that brand overseas.
    However I use a stuffing box with my boat, so I don't actually FILL the tubes with grease- this a target modellers trick , that doesn't work at all well with submarines as you have water pressure to deal with.
    Have a look here for some good modifications to your boats stern tubes-
      If you are US based,
      If you are US based, you can go to any scuba diver's shop and get a container of silicone regulator lubricant.
      The Ace Hardware chain also carries silicone grease - part number 4095667
      Tim
      • tsenecal
        I use the same grease
        I use the same grease on my U47 for the two gaskets and the stuffing boxes. it is a brand that i bought at my local bike shop, it is a silicone grease made for mountain bike hubs. claims to be "water repellant even if submerged". If you need a specific brand name, i will post again when I get out to the club house where I keep it.
        Tim
        • boatbuilder1
          • 386
          hey guys go to your
          hey guys go to your local hobby store and ask for prathers cable grease it is a silicone grease blue in color it comes in a 4 oz plastic jar and that one jar will last for several years I use a syringe to inject it in the tubes it is quite thick I have not had to grease the tubes more than once in 5 years like I said this stuff is really thick
          ca
          • mr t
            • Jun 2004
            • 24
            i use Vaseline - petroleum
            i use Vaseline - petroleum jelly, try it!
            • boatbuilder1
              • 386
              cool vasilene cheap and practical
              but
              but remember don't use it on rubber parts it will eventualy decay the rubber
                Chuck is correct. No Vaseline
                Chuck is correct. No Vaseline on rubber parts - no oil or other petroleum products either. Rots the rubber. Stick to silicone grease. Cheap and easy to get.
