BRASS & WATER - GLUES TO ATTACH
  • nautilus
    • Apr 2004
    • 61
    BRASS ETCH PARTS IN MY PAST, I ALWAYS USED SUPER GLUE TO SET. BUT I HAVE A CONCERN WITH USING THAT METHOD WITH MY SUBS IN WATER, WILL THEY COME UNGLUED? SHOULD I USE A EPOXY GLUE? HAS ANYBODY FOUND THIS TO BE A PROBLEM? IF SO WHAT DID YOU DO TO SOLVE IT? Brian
  • rockpile
    • 48
    Hi Brian,
    Use Goop or RTV
    Hi Brian,
    Use Goop or RTV if you can. It will help overcome the problem of the brass expanding or retracting at a different rate than the non-metalic parts of your sub.
    Best Regards
    RockPile1022
    SCR# 1022
