propel questions - excuse the ignorance
  • petn7
    • 616
    with the SWM WTC, the ballast system uses propel, right? what adapter should i use to get the propel from the can to the copper metal container? are they all the same? the one from subtech should work, right? now, what if i want to use something other than propel, are their other possibilities? like pressurized air for cleaning keyboards? i was reading one post about using something other than propel and i was curious as to if that can be applied to all propel powered ballast systems. so if pressurized air for cleaning keybords works, will the adapter for the propel work for hte pressurized air cans?
  • krowbar
    • Dec 2003
    • 5
    Subtec sell's an adapter, thats
    Subtec sell's an adapter, thats with i use for my SWM WTC works great.
    • petn7
      • 616
      thx for the info
      thx for the info
      • frank
        • May 2003
        • 34
        Most Dust Off products used
        Most Dust Off products used for cleaning key boards and electronic components are CFC's and have the standard aerosol push button. You'll have to make a custom piece for the can valve to fit the Schaeder valve on the pressure cylinder.
        Frank
