which battery? - thor and SWM
  • surge
    • Dec 2003
    • 4
    Here is a reversible brushless
    Here is a reversible brushless controller.
    http://www.rotronindustrial.com/controllers.htm has some, but 11VDC might be a bit high to start. It says at least some of them are reversible during operation.
    HTH
    Seth
      Has anyone thought of scavaging
      Has anyone thought of scavaging a motor from a crashed computer hardrive or floppy for a brushless motor.
      One would still have to come up with a controller.
      Would it have the torque required? desired rpm?
      Could it be reversed?
      Could it be mounted in the rear wall of a WTC to get rid
      of the water tight seal of the prop shaft?
      ]http://www.ohmslaw.com/robot.htm[/url]
      • Larry Kuntz
        • 536
        Not sure if this helps,
        Not sure if this helps, but I found a place on the web called batteryspace.com and their prices seem good. I picked up two (they sell them in pairs) 7.2 volt NiMh batteries for $29. These are 3000 mah and have a drain rating of 30 amps. I plan on using one for my Dumas Akula, if I ever finish it. The weight seems about the same as an older 1500 mah NiCad I have. So, same weight twice the run time, no memory problems. Check out this site. They also have seperate cells if your into building custom battery packs.
