Anyone else converted Bronco's 1/35 Type XXIII to RC
  • redboat219
    • Jan 2005
    • 523
    Does anyone know of any builders other than David Merriman, Big Dave or Manfred ( MFR) who converted or is currently doing a conversion of the 23?
  • warpatroller
    • Feb 2006
    • 308
    Re: Anyone else converted Bronco's 1/35 Type XXIII to RC
    I think Thor stated he converted one. Feng, of ArkModel, looked like he was working on one.. Other than them, no..
    • richard
      • 28
      Working on one right now...
      Rich
        I did convert mine over to R/C. It is a very easy boat to convert. I made a different prop for it and replaced a couple of the appendages that I thought might be easily damaged. The boat handles very nicely, although it is a bit sluggish in turns.
        I am using a very simple gas cylinder in it now. I started off with a pump version, but the pump had leaks in the housing so I am searching for a new make of pump to replace it with. Currently, the XXIII is sitting on the shelf,unpainted, while I get a few version of our new cylinder prepared to go out to a few friends as test platforms and getting my Permit, Sturgeon, and Kairyu ready for the SubRegatta in Keystone, Colorado in July.
          What sort of water pump are you using?
            Hi Andy,
            It is a high volume, low pressure centrifugal cooling pump. I have a very nice one coming, but it is fairly expensive. We'll see how it works. The cheap pump from china was a complete piece of junk.
              There is this company here in the UK. I haven't tried their pumps, but they look like high quality items, and they're very small units.
              • redboat219
                • Jan 2005
                • 523
                Matt,
                Can you post some photos of your boat?
                  Certainly. I will put some photos up as soon as its painted. Its in its native plastic right now, and the cylinder is now in my Permit getting ready for the KeyStone Regatta.
                  Thanks for the link, Andy! Finding a good quality pump that will last is a challenge.
                    The pump that failed, was it the same as this one?
                    • redboat219
                      • Jan 2005
                      • 523
                      How bout the wtc?
                        Andy,
                        It looks just like that pump you have shown here. It has a polycarbonate housing with a free floating rotor. The volute to the pump is threaded on to the front of the pump. 2.2 L/min. It worked well for about an hour of operation, then failed. The second pump didn't last as long as the first.
                          This one is rated at about 1.5litre per minute on 12 volts. It's very small about an inch diameter.
                          Only carried out bench tests on it, but seems to be reliable so far. They don't like to be run dry.
                            • 2361
                            Got a pool run in. Here it is:
                            • redboat219
                              • Jan 2005
                              • 523
                              Good job!
                              Can't wait to get mine...
                              Wonder how she behaves without an angle keeper.
