gears
  • mar7ck
    • 198
    gears
    Does any body know a good scource for gears, shafts amd assoc parts???
    Thanx
    The Small Sub Guy
    Dunno if you're based in
    Dunno if you're based in the UK. But if you are, then I'd highly recommend HPC gears and also Muffet gears.
    I've dealt with both companies and received excellent service from both. Definately modeller friendly! lol
    MANUFACTURER AND STOCKIST OF GEAR TRANSMISSION AND ENGINEERING PRODUCTS
    HPC have a bigger range, but tend to be a bit more expensive than Muffet.
    Cheers
    • d manley
      • 122
      http://www.wmberg.com/ http://www.subcommittee.com/forum/icon_biggrin.gif
        Where do you find the
        Where do you find the screw drive rod that is used in a piston
        tank.
        Would a 1/2" threaded teflon rod work for this rod?
        • no1_sonuk
          • Oct 2003
          • 11
          You might have trouble if
          You might have trouble if you want to glue anything to the Teflon.
