End caps for WTC - Any suppliers?
    It appears that Mike's Subworks has suspended production for the immediate future...
    Does anyone have WTC endcaps for 2.25" ID Lexan tubing?
    Why not make your own?
    If
    If you're really stuck I'll turn some up for you out of acrylic.
    • mar7ck
      • 198
      I too have need for
      I too have need for WTC endcaps for 2.25" ID Lexan tubing.
      I am look for some who can help me out for a reasonable cost.
      The Small Sub Guy
        • 880
        Would PVC be a good
        Would PVC be a good material to turn them endcaps out of?
        Maybe buy a PVC plumbing pipe cap and turn it from that.
        • fung pang
          • 91
          all you need is some
          all you need is some card stock, Smooth-On or Alalumilite or other liquid casting plastic, to make the end cap.
          and a short piece of the tubing in the size (any size!)you need.
          have the card stock go around the tubing two three time, tape it down, push it out out about 1/4", you have a mode.
          see end cap is read bad wed page I will try to fix it.
          no need to buy a turning machine.
          is cheap, and fast.
          fung pang
          SC #400
            Neat idea FP! Many of
            Neat idea FP! Many of us don't own a lathe.
            Can you supply a little more information on the fabrication and use of the cutter and spacer?
            Tim
