Ping Rate????
  • ramius-ii
    • Apr 2003
    • 393
    Ping Rate????
    Hi All!
    Just a quick question about when a sub does pings.
    How often does a sub send out a ping? 3 seconds, 5 seconds, more, less?
    Inquiring minds wish to know!
    Thanks, Ed
  • raalst
    • 1229
    Re: Ping Rate????
    I have no idea about real sonars, but the limits are that they will probably expect to ping up to a kilometer.
    that means 2000 meters of travel, which means you hear the echo in 2000/1500 seconds, as sound moves
    roughly 1500 meters a second in seawater.
    so the minimum time between pings would be just over a second.
    however, pings will take a time to transmit and range might be larger.
    Which means longer periods inbetween pings.
    so, one second seems to be the minimum time between pings.
    I expect *real* submariners do not use active pings. it's unhealthy
