F-14 Modules - Can you add up to 3?
  • kd6hq
    • 102
    Being new to subs I have been reading a lot lately. I have been using a F-14 radio for quite awhile now and have a basic understanding of how it works. One of the threads that I read someplace mentioned that a second switch module (8101) could be added in series by using the plug on the back of the module. Which is easy enough but where does the second 8370-module go? Does it plug into the next channel? For instance if the first 8370 goes to channel 6 then does the second one into channel 7? I can’t see any other way to do it. Unless a ‘Y’ adapter is used on channel 6?
    Is it possible to put 3 8101-switch modules in series?
  • feet wet
    • 213
    Yes, although the directions are
    Yes, although the directions are terrible,putting the modules in series is what is done.The three prong plug for the first module connects to the MULTI-OUT pinwith its single wire lead going topins 1,2,or 3 in the right hand pin cluster. the next module multi-pin now connects to the multi-pin on the BACK of the first module ,the single lead of the #2 module goes next to #1's single lead on the main board.Module #3 is series'd the same way.
    Good Luck
    JE
