Taking a poll on water pumps - what type water pump do you use ?
  • smwarships
    • 104
    Hello All ,
    What type water pump do you use ?
    Where did you get it ?
    Is the pump you use reversible ?
    What was the cost ?
    How dependable is it ?
    Does anyone use windshield water pumps ?
    If so , for what car ?
    Darle
  • jeffg
    • 28
    I use the Tee vavle
    I use the Tee vavle and water pump from Skip Assay and it works fine.
    • david h
      • 199
      G'day
      I use a Dick Smith
      G'day
      I use a Dick Smith Electronics Centrifical high pressure water pump. it's hermetically sealed and is one way. Use a pinch line with a metal geared servo. (Dick smith is an aussie electronics firm. They have a webpage you could probably look up.
      V reliable pump.
      regards
      david Hughes.
      • koeze
        • May 2003
        • 204
        I'm using a pump that
        [color=#000000]I'm using a pump that is sold in hardware stores. It is supposed to be attached to an electric drill. I have adjusted (improved) the seals and attached the driveline of an old electric screwdriver (Johnson engine with double planetary gears).
        The pump has quite a large flow (33l/min) but by using a geared down engine the flow is reduced. This way I can fill my 2 liter ballast tank in an acceptable time.
        Cost]
          My 1/32nd scale Type VII
          My 1/32nd scale Type VII uses a Shurflo pump with a solenoid-based check valve.
