Bursting Pipe Joint?
  • ramius-ii
    • 393
    In movies when a sub is in trouble you always see pipe joints or pipes bursting. What is the function of theses pipes?
    Thanks, Ed
  • tabledancer
    • Feb 2005
    • 573
    Re: Bursting Pipe Joint?
    To get the actors wet and make it look like they do something besides looking pretty!!!!!!!!!
    TD
    • Rogue Sub
      • 1724
      Good call!
      Its just the movies and you have to take it at face value.
      • ramius-ii
        • 393
        While it is easy to agree there was a special on training submarine crews and part of the training they showed were guys installing patches on broken / leaking pipes which gave the impression that pipes could have problems. Or am I just confusing one thing with something else?
        • Rogue Sub
          • 1724
          We are trained to fix pipe burst yes. Could be any seawater or hydraulic system that it happens to though. A few scenarios are exceeding test depth and pipe pressure ratings and bursting them or a close aboard explosion causing them to rupture. In these cases we might need to patch a pipe or secure the system all together... Does that help?
          • ramius-ii
            • 393
            Yes a little I think. Hydraulic systems are understandable and that would be I would imagine oil. What systems use seawater? The ballast system, showers, toilets, engine cooling or are there other uses?
            • Rogue Sub
              • 1724
              airconditioning, electronics, main engine condeners, diesel seawater cooling, toilet...lots of stuff
              • ramius-ii
                • 393
                Thanks very much! I was asked since I am working on a model and I did not feel I had very good asnwers so I thought it best to ask the people who really know!
                Best, Ed
