Gato Sub Question
  • jimdavis
    • Jul 2012
    • 35
    Gato Sub Question
    All the experts on the Gato Class Sub in WW II I have a question, Did they use liquid mercury to fine trim the subs, transfer from front tanks to back? I am following up on a story I was told.
    jd
  • tom dougherty
    • 1361
    Re: Gato Sub Question
    I have never seen any mention in any Fleet Submarine manual about using liquid mercury. The trim tanks used seawater, and the amounts fore and aft were adjusted as needed with trim pumps.
    Here's the manual if you want to look yourself: http://www.hnsa.org/doc/fleetsub/trim/index.htm
    The only large scale use I am aware of in a submarine of mercury was in the short lived sodium reactor on SSN 575 in the 1950's. Mercury was used as in intermediate loop between the liquid sodium primary (reactor) loop and the steam secondary loop. Obviously any direct contact of highly reactive sodium and water was to be avoided, so mercury was initially employed in an intermediate heat transfer system. Cooler heads prevailed after some leaks, and the mercury replaced with a potassium-sodium liquid mix.
      I second Tom here -- seawater was used for trim (though I don't consider myself a Gato expert by any stretch).
      What I do recall (I think) is that the Cousteau Diving Saucer used mercury pumped back and forth for trim.
      • jimdavis
        • Jul 2012
        • 35
        Thanks for the replys, I think I was told a tall tail, as it involved diving on the wrecks after wwII and drilling the hull and pumping out the mercury, the story teller has passed on, but it was a good story
        JD
        • giovanni
          • Mar 2012
          • 207
          There was mercury in storage vats on a torpedoed Type VII off the Scandinavian coast.
          It was torpedoed by the British submarine. The type that OTW produces.
          • jimdavis
            • Jul 2012
            • 35
            No the story that was told it was US ships and Mercury, I know of the U-boot that you are speaking of and I beleive they are trying to figure a way of cleaning up that mess.
            jd
            • tom dougherty
              • 1361
              Most lost fleet boat wreck locations were not known after the war, and some have only been found in recent years. Almost all are sunk well below any depth a diver can reach, and further are considered war graves, not to be disturbed. Again, I know of no large scale mercury on board those boats.
              The only other story that is true is that metal from the scuttled German U-boats of Operation Deadlight is currently being recovered to use in extremely sensitive radiation detection instruments. Steel made after the war (which uses prodigious amounts of oxygen to make from iron ore) has higher background radiation from all of those atmospheric nuclear tests we (and others) conducted post WWII. No mercury there, either...
