Weld line article
    • 880
    Weld line article
    Great article on weld lines in the newest SCR magazine.
    Especially liked the title art work.
    May have missed it in the article; but is the products used
    to make the weld lines waterproof/water-resistant or is the
    finish coat needed to seal it from the water if used on a RC
    boat?
    Haven't been able to read the rest of the articles yet but the
    look good as I flip through.
    Scott
  • boss subfixer
    • Aug 2004
    • 656
    Scott,
    I would say it's water
    Scott,
    I would say it's water proof, it's for painting designs on fabric. And your right, it is a great article.
      inspired by this article I
      inspired by this article I have done a few tests with nailpolish.
      that's good for rivets. it leaves flat but visible rivet heads.
      you can still feel them.
      the small ones in the picture are about a mm wide.
      • oldmscle
        • Jul 2008
        • 31
        Re: Weld line article
        Sorry I haven't gotten to a reply to your post, I've been having computer problems and finally had to break down and buy a replacement.
        Thanks for the kind words about the article. I tried to keep it simple yet informative. To answer your question, YES that stuff is waterproof and very durable. Once dried it has a slightly rubbery consistency, but ther only way you'll remove it is to literally cut or sand it off. Once you paint over it you'll find it to be a permenant part of the boat. The best part is, a bottle of that stuff is only 39 cents and will last forever! Hope that helps.
        Lyle
