Well after alot of testing and failures I have determined that there is really no reliable way to "waterproof" servos for submerged use. They all seem to get wet {just enough} inside somehow or another. O-rings,tool dip,glue,tape,liquid electrical tape,vaseline etc has proven to be "water resistant" at most. I never really liked the idea but tried to make it work....
There is a big difference beteween putting a servo in a cup of water and actually using it in a sub for hours on end. Even meticulous preperation of the servo failed after a few hours of operation, and NEVER on the bench. So I will use small water tight boxes for each servo; the little containers with the clear lids so I can see WHEN {not IF} the water gets in
Just thought I'd share my findings with the group, I know that there is nothing more frustrating than checking everything at home, everythings great, then putting it in the water and 10 minutes later its all the way back home and into the shop.
