Newbie
  • thefreak
    • 2
    Newbie
    Hey iam new to R/C submarines and need some direction on how to get started.
    What is the best way to start out?
    Any help would be greatly appreciated Thanks.
  • robse
    • 183
    Hi, and welcome!
    I'm a first
    Hi, and welcome!
    I'm a first time builder as well, and I would recommend the following]http://www.subcommittee.com/forum/icon_smile.gif[/img]
    I'm doing an Ohio class sub, a 2m (6ft) from scratch (Except the hull, buying that from http://hjem.get2net.dk/robse/SSBN/SSBN.htm and see if it helps you on your way deciding the correct approach for you, into this GREAT hobby.
    Also, take a look at www.ThorDesign.com for kits, hulls etc. and don't forget to "shop around" a little, until that perfect kit stares you into the eyes.
    Sub's technology holds a few supprices along the way through design, and fitting. Lean on other builders, and get ready to learn about positive and negative buoyancy, compressed air, static vs. dynamic dive systems, radio issues and alot of other things. You've got hours and hours of great fun ahead! Good luck.
    • seawolf
      • 107
      Sorry, didn't mean to Spam
      Sorry, didn't mean to Spam or other disadvantage purpose. I just want to express my feeling about ur site Robse.
      It is GREAT - I think I will learn a lot from ur technique, even I haven't start to get wet into the RC world.
      thanks for the site.
      rgd,
      Fiat
        • 682
        Might I humbly suggest that
        Might I humbly suggest that you consider joining The SubCommittee? Our quarterly magazine, The Report, is full of all kinds on info on building R/C subs, details of the real thing, how-to info, etc. Also, the camaraderie of joining up with fellow sub modelers can't be beat. Nothing quite like getting together with a dozen other guys running subs and sharing ideas.
        Best Regards,
        Jim Butt
        Membership Chairman, The SubCommittee
        • robse
          • 183
          Hi again.
          Thanks, SeaWolf! Great to
          Hi again.
          Thanks, SeaWolf! Great to hear some positive responce on my site. I'll update it as work progresses. (More pic's later this week)
          SubDude: Yes, you're right. Sorry I forgot to mention it. I'll be joining shortly myself.
          • thefreak
            • 2
            Thanks everyone for all you
            Thanks everyone for all you help I really enjoyed robse website it is wonderfull. I havent finished reading all the material there but I will. I also have one more question how far can a Remote Control System reach through water? Basicaly I wanna know how far I could take my sub underwater if I had hull that could withstand the waterpressure.
            • seawolf
              • 107
              Robse, u're welcome http://www.subcommittee.com/forum/icon_smile.gif -
              Robse, u're welcome - u earn the credit
              quite related to what TheFreak posted, I'm thinking of a simple subs that can move, dive and surface - using remote control system instead of radio control.
              if say, the subs it self is waterproof, and using a dynamic diving system - we can have the power from the controlling unit (battery, etc) with a cable run up to the boat. It will be limited to certain range of course but for start what do you think ?
              • robse
                • 183
                Hi again.
                First of all, thanks
                [color=#000000]Hi again.
                First of all, thanks both
                To the Q's:
                1) How far can a radio control reach into the water:
                Well, it depends on the water. Salty & pools are the worst, fresh water lakes are the best. Typical radios can go about 6-8 ft. into the water with no problem, but if you build a system where your antenna is draged behind the sub in a surface-towed sonar in a long cable while the sub is submerged, that problem is solved.
                As you can see in the section above, the radio will not make all it that deep, unless you build the "Towed sonar" idea. Please see this link for more info on sub radio issues: R/C Submarines
                2) The run-by-wire]
                • robse
                  • 183
                  just lettin' you know]http://hjem.get2net.dk/robse/SSBN/SSBN.htm and
                  just lettin' you know]http://hjem.get2net.dk/robse/SSBN/SSBN.htm[/url] and look for the sections under "My Results"
                  Also added]http://www.subcommittee.com/forum/icon_smile.gif[/img]
