RCBoote
    RCBoote
    John,
    Are you referring to the http://www.rcboote.at web site?
    When you go to the forum, look for the "Registrieren" hot spot along the top red menu bar.
    Of course, if you cannot read German, it'll be a bit difficult to understand the discussions! Verstehen Sie?
    Are you referring to rcboot.de?
    If
    If so, I use the Google translator e.g.
    http://translate.google.co.uk/translate ... n&ie=UTF-8
    My German is virtually non existent, but I get by using the translate function on the forum.
    Also most of the members on the forum speak and write English, and providing you're polite will answer any questions you have.
    • hakkikt
      • Jun 2006
      • 246
      The required fields (with asterisk)
      The required fields (with asterisk) are, in this sequence:
      username
      e-mail address
      password
      repeat password
      confirmation code (the stuff written in the colourful box)
      The info about the confirmation code (human/bot detector) says that there are capital as well as small letters, and that a zero differs from an "o" by having a line through it.
      Click on "Absenden" to register.
      All pretty standard, so I suppose your problem might be another one. Maybe you have to allow Java or something like that?
      Hope that helps.
      • robert f.
        • Jun 2006
        • 161
        John, I registered somewhere last
        John, I registered somewhere last year without any problems.
        If you want, I can try and register for you. If so, send me a pm with your e-mail address, preferred user name and password. When registered succesfully, I will let you know, again by pm.
        Robert
