Retract servos
  • tabledancer
    • Feb 2005
    • 573
    Retract servos
    Hi,
    It`s me again,does anybody know where I can get a mini retract servo.I`m using it to retract the bow planes on my Gato and a normal and compact size just won`t fit.The only way to put one of those is to go outside the WTC and I just don`t want to do that.
    TD
  • Rogue Sub
    • 1724
    do you need a micro
    do you need a micro or sub micro
    • tabledancer
      • Feb 2005
      • 573
      I need a micro servo
      TD
        I posted a link over
        I posted a link over at SP which was for a mini retract servo.Micro servos are smaller still,and i haven't seen a micro retract servo.
        However most (all) servos can be made to rotate 180 degrees, and with a little modification will go to 270 degrees. You just need a servo pulse stretcher to extend the 1 to 2ms pulse from your receiver.
        • fgroza
          • Jun 2005
          • 168
          From RC Dude hobbies, they
          From RC Dude hobbies, they have a servo stretcher which plugs into the lead and makes any servo a retract 180 degree unit- $10 for the item. Check them out for other neat items.
          Frank
