Engle BTS problems - Failed fail safe
  • joeangi
    • 21
    My BTS on my Engle tank works fine, but the RF failsafe no longer drives the motor to full blow. The motor just jumps after the 8 second delay and stops. Anyone out there have any suggestions?
    Thanks,
    Joe
  • jlemons
    • 11
    On my Typhoon it was
    On my Typhoon it was doing something similar to that. It turned out to be the shoulder bolt that supports the idler gear. It had galled up causing it to jam when trying to surface. I had to increase the size of the hole in the gear by a couple of thousandths. That seemed to remedy the problem.
    • joeangi
      • 21
      Thanks for the info...I will
      Thanks for the info...I will look at it tonight.
      • joeangi
        • 21
        Was your tank functioning properly.....mine
        Was your tank functioning properly.....mine runs properly in both directions. It is just when I turn off the transmitter to simulate loss of signal that it does nothing.
        • jlemons
          • 11
          Mine just locked up. I'm
          Mine just locked up. I'm not sure on what would cause it when you have a signal loss. You might e-mail Engel thay are real good at helping to track problems.
            Hi,
            I recently purchased two of
            Hi,
            I recently purchased two of these to use in my Type VII. Although I have'nt installed them, I have tested them .... except for a loss of signal.
            Is this part of the normal package he sells or was it something extra you bought?
            My version is the one that requires a servo...The EA750.
            Mike
            • silent hunter
              • 45
              The best thing to do
              The best thing to do if you have any problems withan Engel product is talk to Greg Engel. He knows the product better than anyone, and is quick to respond when able to, which is alomost all the time.
              Richard
