A little help please
  • westy33
    • Nov 2026
    Just bought a set of plans from Deep Sea designs of the LA Class. I am in the process of laying glass for the hull and then it dawned on me. what size engine, gear reduction, servo size, battery type and size? Never gave this much thought. I know I could buy these pre-made as a unit or kit, but I am looking to do this as much of this on my own skill. I have servos from my planes which should do fine. I have never messed with electric motors and gear reduction. Is there a formula for if sub weight is X you need Y motor and Y gear drive. I guess that would go for the servos also could I get away with using the mini or micro servos in stead of the standard sized servos? I know there are a lot of question NOOB to subs.
  • redboat219
    • Jan 2005
    • 523
    Get one of David Merriman's
    Get one of David Merriman's 3" sub-driver. It already comes with motor, gear train and gas ballast system.
      What size boat are you
      What size boat are you building? I run a WTC-3 in my 1/96 scale LA boat and it works well.
      Dave Manley of Small World Models has a nice line of WTCs as well. You can buy them complete or in components to do the construction work yourself as you seem to indicate wanting to do. http://www.geocities.com/smallworldmodels/index.htm
      I see SWM is offering recession specials on their kits. You may be able to talk Dave into dealing on his WTCs as well (no promises, though).
      • myles yancey
        • Mar 2005
        • 282
        Re: A little help please
        Hi westy33
        you mite want to give the scale and dementions of the sub you are building, this way members can give you more in depth answers to your questions, in stead of just the general answers.
        The dementions will be of great help them, when they give you an answer to your questions.
          Just to add to what
          Just to add to what prez Myles said, you can buy endcaps, lexan tubing and seals from outfits on the vendor's page to make your own cylinder - though I must say - buying a WTC pre-made helps get your first sub in the water much faster. Then with your next sub (there ALWAYS is the next sub) you can mess around building a WTC. So many first timers get frustrated buiding a WTC and their boats wind up on Ebay.
          • kazzer
            Banned
            • Oct 2006
            • 324
            We're dumping 3" cylinders - obsolete! We now have 2.5" Sub-drivers using less space and doing the same job.
            Soon to be available in 'assembled' and 'kit' form, to make it more cost effective for you.
            I completely understand the frustration of 'first timers', I was one only a short time ago. I've been there, dun that and Merriman & my business is fully aware of the problems a novice has with this hobby.
            Thanks for pointing it out Tim!
            • warpatroller
              • Feb 2006
              • 308
              I was actually considering that "obsolete" cylinder for my 32P XXIII. The 3" was considered, by many, to be a perfect match for this hull. Since you've eliminated the 3" WTC, I suppose I will just have to make my own...though I believe Mikessubworks has 3 inchers available with a belt driven reduction system, so that's another possibility.
              • kazzer
                Banned
                • Oct 2006
                • 324
                I just spoke with Merriman about this and he confirmed the following.
                The reason the 3" is considered a perfect match is that many people have this unit already, and they like it. That's good!
                However, over the past couple of years, we have seen much smaller servos, pitch controllers, speed controllers etc. etc. so the Aft Dry Space required is considerably less, meaning the cylinder can have a smaller diameter.
                The major consideration is the ballast tank volume. In the old 3" unit, the total volume is 11.5 fl oz, whereas the new 2.5" cylinder has 12 fl oz. This is simply an improvement on a good system.
                • warpatroller
                  • Feb 2006
                  • 308
                  The 2.5" cylinder must have
                  The 2.5" cylinder must have a longer ballast section than the 3" to have more volume (even to have the same volume) in its tank. As a result the forward and aft compartments must be shorter in length than the 3" cylinder allowing for not only less room in diameter but also in length inside those compartments. Or maybe the 2.5" overall length of entire unit is longer than the 3" was?
                  Don't think I'd want those little micro servos (like you have in the small Sub Drivers) to be working the planes and rudder of the 32P XXIII (which is a bigger/heavier boat with larger appendages than the static conversion Revell/Trumpeter models. I already have the relatively BIG Polk Seeker II receiver also, which takes up space.
                  • kazzer
                    Banned
                    • Oct 2006
                    • 324
                    The kit can be altered in cylinder length.
                    The 2.5" cylinder will also accept our standard size servos.
