Any thoughts on this?
  • u-33
    • Jun 2008
    • 309
    I wonder if it's possible to convert this plastic kit to r/c, even if it's only for surface running?
    I can't work out how big it is, but I'm guessing around...12" oal?
    Rich
    (just found a website covering this kit... http://www.hlj.com/cgi-perl/tanoue/f...?Code=FNMFS-02 )
    Its not all that big...34.0 x 19.0 x 4.3. Might just be a bit of a squeeze...
    If you thought Steve's 212
    If you thought Steve's 212 was tight for linkages then you'll be having a ball with that one!
    Knitting fog might be simpler.
    • u-33
      • Jun 2008
      • 309
      The linkages appear to be
      The linkages appear to be external Andy...I think.
      Rich
      • redboat219
        • Jan 2005
        • 523
        this might help
        http://forum.sub-driver.com/showthread.php?t=257
        this might help
          No, I'm sure they're internal.
          Here's
          Here's a link to some pictures of a fullsize version-
          http://www.williammaloney.com/Aviation/ ... /index.htm
          • u-33
            • Jun 2008
            • 309
            Excellent, thank you both...much there
            Excellent, thank you both...much there to study.
            Rich
            • u-33
              • Jun 2008
              • 309
              So what do we think
              So what do we think then, boys and girls...is this going to be feasible to convert to r/c? Maybe only surface running, that way I'd only have the rudder to hook up in that tiny stern section.
              Any more ideas/comments?
              Rich
                There's equipment available small enough
                There's equipment available small enough to R/C it, but it really is a very narrow hull to work in. If you want a baby submarine, there are better subjects for conversion....
                • u-33
                  • Jun 2008
                  • 309
                  Hmm...the price attracted me, less than £20 inclusive of postage. Perhaps I'll build it as a static model then.
                  Rich
                    just for inspiration :
                    http://www.micmo.de/uboot/index.htm
                    it
                    it can be done ! just start.
                    • hakkikt
                      • 246
                      At the Neulengbach meeting a
                      At the Neulengbach meeting a few years ago, I saw a guy with a 1/144 Revell Type 209, and it was a static diver! The models are roughly the same size (I have both), so a conversion of the Kaiten is certainly doable.
                      One trick that he applied was using cables to transfer server movement to the control surfaces.
                      • u-33
                        • Jun 2008
                        • 309
                        just for inspiration ]http://www.micmo.de/uboot/index.htm
                        it can
                        just for inspiration ]http://www.micmo.de/uboot/index.htm[/url]
                        Ronald, you are indeed a source of inspiration to me, those little fellas are really..well, little!!
                        Hakkikt...you as well sir, many thanks for the help. Watch this space...
                        Rich
                        • u-33
                          • Jun 2008
                          • 309
                          OK, so presuming there's room
                          OK, so presuming there's room to install mini r/c equipment, any ideas as to how to install and waterproof it? I guess a WTC is out of the question? Or is it...?
                          Questions, questions...
                          Rich
                          • hakkikt
                            • 246
                            The guy with the 1/144
                            The guy with the 1/144 Type 209 did not use a WTC - he cut the hull somewhere ~2/3 from the bow, where it was still cylindical (not a cone) and waterproofed the connection with an o-ring (perhaps with a bayonet-type connection, but I am not sure - probably it was just one part moved against & above the other and fixed against turning with a screw).
                            The motor was in the back part, and everything else was in the front part, very nicely to be seen after the forward part of the hull was removed.
