dive vanes....
  • u-33
    • Jun 2008
    • 309
    dive vanes....
    What are your thoughts on connecting front and rear dive vanes to the same servo? Just wondering which is the way to go here…
    (a) front vanes up…rear vanes up and front vanes down, rear vanes down
    or
    (b) front vanes up…rear vanes down and front vanes down, rear vanes up
    Rich
    How about:
    c) front dive planes
    How about:
    c) front dive planes connected to servo, used to control depth and aft dive planes connected to a different servo and a different channel, which is in turn connected to a pitch controller used to control pitch.
    • ricknelson
      • Dec 2006
      • 186
      Rich,
      Weither or not you take
      Rich,
      Weither or not you take Jeff's suggestion, option (b) is the only one that can work. If you chose option (a) your controls (diving planes, stern planes) will be fighting each other.
        How do you figure that
        How do you figure that Rick?
        Both vanes will be producing down thrust, the boat should dive and rise on the level with such a set-up.
        • Wheelerdealer
          • 315
          a) is dive and surface
          a) is dive and surface with no change in pitch, and b is dive surface with a change in pitch.
          a) is good for a ballasted down dynamic diver with little freeboard. b) is better if you have a lot of buoyancy/crash dive.
          I've never had a dynamic diver with foreplanes so have never connected both planes together. Always done it the way Jeff suggested when I have working forward planes.
          • ricknelson
            • Dec 2006
            • 186
            In theory and small submarines
            In theory and small submarines (a) may work but on 1:1 boats we had to take eithor a 10 degree up or down angle opposite to the bow planes in order to make them more effective.
              I think it's because the action of the dive planes causes a pitch axis rotation around the center of gravity. Hence stern planes in the 'up' position cause the stern to rotate upwards around the c.g.
              • u-33
                • Jun 2008
                • 309
                But wouldn't that help force
                But wouldn't that help force the boat down quicker...pushing the nose down and the stern up would surely steepen the dive angle? Or am I barking at the wrong cat?
                Rich
                  It will be more effective,
                  It will be more effective, but if you try that trick with a too much freeboard, the stern of the boat will lift out of the water and prop will thrash about in the air.
                  • ricknelson
                    • Dec 2006
                    • 186
                    Another factor that needs to
                    Another factor that needs to be taken into consideration, especially with boomers and some degree fast-attacks, is that the hull aft of the fairwater acts as a lifting body. This comes into play at higher speeds. Again, I speak primairly for 1:1s.
                    • u-33
                      • Jun 2008
                      • 309
                      To hell with the expense,
                      To hell with the expense, I'll buy another servo!!!
                      Rich
                        Good idea.
                        Good idea.
                        • u-33
                          • Jun 2008
                          • 309
                          http://www.subcommittee.com/forum/icon_lol.gif
                          Rich
                          Rich
