replacement for propel - propel staining
  • mar7ck
    • 198
    Is thare something other than propel that can be in derect replacement for propel. This stuff is staining my wtc.
    Thanx
    SUPER DUSTER REFILLS -
    This stuff
    This stuff doesn't have butane - that besides staining your WTC, also seems to corrode other parts it is exposed to.
    I have had the best luck getting it from Circuit Specialists in Arizona.
    Circuit Specialists Inc.
    220 South Country Club Drive #2
    Mesa, AZ 85210
    Phone]jr@cir.com[/email]
    These are the folks that Mike Dory referred me to. I once tried to buy a case from an outfit in New Jersey and it was a nightmare!
    Also make SURE you order the refills, not the ones that come equipped with plastic triggers. Those won't work.
    The correct item will say "For use with M.G. Chemicals Cat# 402-T Chrome Plated Trigger Valve". THAT is the one to get. You can just click on the link below and go right to the correct page on their ecommerce site.
    Tim
    PS - one more thing - be sure to order early. They don't have a huge stock of this stuff so don't wait a week before a regatta and expect to order a case ($5.15 per can in case lots vs $5.50 ea per single unit) to order!
    HERE IS THE WEB PAGE
    http://store.yahoo.com/webtronics/402ar.html
    • jimjam
      • 9
      I simply cut of the
      I simply cut of the end of the tube from a bottle of Fix a Flat. Went to Pep Boys and got a chuck? that has a spring loaded handle you add air to tires with. Put it on the end of the Fix o Flat hose. Just pop off the Super Duster cap and place the new one on. Now I can just walk into just about any store, Walmart,Best Buy ect and pick up a few cans of Super Duster.The plastic one that comes on the Fix o Flat can is plastic and works but wears out. Thus the metal one. Just a suggestion that makes getting air easier and avoid running out and having to order.
      Edited By JIMJAM on 1057690793
      • jimjam
        • 9
        Just got back from SAMS
        Just got back from SAMS Club. They had a 4 pack of air simular to S Duster for $6.00 Now thats more what canned air is worth.
