Calculating ballast tank size...
  • u-33
    • Jun 2008
    • 309
    I’ve decided to build my Steve Neill U-212 as a dynamic diving boat, at least to start with ( I can almost hear the hoots of derision and howls of laughter incoming…) but there is a major reason for this. Present finances won’t allow me the luxury of the proper BigDave WTC unit for it, so until I am in a better financial position to spend some more cash and top up BigDave’s bank account, for the time being 212 will be diving under power only.
    The idea is to build in a (temporary) home brewed WTC of sorts, using a length of clear Lexan tube from these guys http://cgi.ebay.co.uk/ws/eBayISAPI.d...rkparms=tab%3D
    a small ballast tank powered by a screenwash pump to take on just enough water to go from surface trim to decks awash and then to dive the boat from there. That will give me a built-in failsafe because the boat will have sufficient buoyancy to return to the surface should things go wrong, so all isn’t that bad.
    OK, two questions then…firstly, how much of which diameter Lexan tube do I buy? And how do I calculate the size of the ballast tank and the required amount of water to get from surface trim to decks awash?
    Stood standing by…..
    Rich
  • Wheelerdealer
    • 315
    I'd go for the same
    I'd go for the same size that BD uses in his kit. Minimum volume of the ballast for your dynamic diver is the diffterance in the displacement of the sub at its surfaced position and the desired waterline when the ballast tanks are full (as your is a dynamic diver). So basically you need to measure the volume of the hull and the volume of the WTC between these two positions.
    The link is for acrylic tube which is differant from Lexan (polycarbonate) but still fine for the purpose.
    • u-33
      • Jun 2008
      • 309
      Thanks Ramesh, I guessed it
      Thanks Ramesh, I guessed it may be something along those lines, thanks for the help.
      What size is BD's tube..any ideas? I've been through his site time and time again and I can't find it....
      Rih
      • Wheelerdealer
        • 315
        Its 2.5" OD according to
        Its 2.5" OD according to this page http://www.frontiernet.net/~bwelch/type212.htm
        Thats about 63mm.
        • u-33
          • Jun 2008
          • 309
          Fantastic, thanks mate...appreciate that. Just
          Fantastic, thanks mate...appreciate that. Just gonna order it now...
          Rich
