Running solenoids wet
  • Rogue Sub
    • 1724
    We run motors wet.
    Batterys wet.
    I figure why not solenoids.
    Any coments on this one guys. I am going to try it out and hope that it doesnt fail and sink my ship!!!
    Be prepared to replace them
    Be prepared to replace them each season.
    In my first homebrew Propel system I had in my Hunley, the tank vent solenoid started to arc after about a year.
    It made for an exiting couple of minutes at the SubVets convention in Duluth, MN when smoke started to pour out of the hull!
    Tim
    • Rogue Sub
      • 1724
      LOL thats funny my last
      LOL thats funny my last solenoid just did the same thing and it was essesialy water proofed. Perhaps I will order a few extra or consider an new setup.
        • 684
        yep
        Been running solenoids in the wet for many years. Works great. May I respectfully suggest that you consider using WATERPROOF solenoids?
        • Rogue Sub
          • 1724
          By all means make any
          By all means make any suggestions that you like.
          I only ask that you help direct me tword your suggestion, as I have no idea where to find them!
          Kevin
            • 684
            Hi Kevin,
            Like many good submarine
            Hi Kevin,
            Like many good submarine supplies, they can be found at http://www.mcmaster.com/
            Search for solenoid, you'll have lots of choices. I like the 69905K2 12v one.
            Good luck!
            • Rogue Sub
              • 1724
              appreciate it
              any idea where you
              appreciate it
              any idea where you can get a 6vdc one
              all of my boats run on 7.2vdc
              • KevinMC
                • Sep 2005
                • 463
                For what it's worth, I
                For what it's worth, I have an app where I need to run some solenoids in the wet. Is there anything in particular that's been found to work to extend the life of a non-waterproof solenoid? (Waterproofing techniques?)
                KMc Designs
                  This fella in Germany sells
                  This fella in Germany sells surplus solenoids designed for venting tanks etc. from time to time-
                  http://www.respotec.de/shop/start.htm?m ... ventil.htm
                  They look like they're well suited to be waterproofed with a bit of RTV silicone.
                  Sells lots of other goodies for model subamriners too.
                  • Rogue Sub
                    • 1724
                    I have tried taking solenoids
                    I have tried taking solenoids and covering them with rtv and a flexible boot to waterproof. It did well for about a year then it set on fire. It eventually formed a leak and began taking in water which could not then also drain out. I have also noticed a problem that they act like the pitson in a car. Once you seal it up, one end has no where for the air to go once retacted and it drops the strength of the solenoid considerably.
