Paint remover
  • steve jensen
    • Nov 2006
    • 31
    Paint remover
    What type of paint remover canyou use on an epoxy fiberglass hull?
    Sanding will erase the existing scribed lines, and a re-paint would probably fill in some of them on this L.A. Class boat.
    Thanks for the help and...
    Happy New Year!
    Steve Jensen
  • tsenecal
    The Plastic Model types use
    The Plastic Model types use the spray on oven cleaner to remove paint without damaging the plastic.
      Brake fluid is pretty effective
      Brake fluid is pretty effective too.
      • steve jensen
        • Nov 2006
        • 31
        paint remover
        Gee...this stuff sounds rather harsh...knowing that I have cleaned the oven and stove with those products (not the brake fluid)...and was amazed at the strength of it.
        When you use the word plastic; exactly what type of 'plastic' are you referring to?
        Maybe I can do both the stove and the boat at the same time...hmmm.
        Thanks,
          I find oven cleaner works
          I find oven cleaner works okay on oil paints. Cellulose or acrylic finsihes can be a bit more stubborn in my experience.
          Oven cleaners contain sodium hydroxide or potassium hydroxide, nasty stuff, so use it in a well ventilated area.
          Brake fluid seems to take anything off!
          • tsenecal
            The type of plastic I
            The type of plastic I was referring to is the generic "injection molded plastic" that firms such as Revell or Tamiya produce their kits with.
              Steve,
              For an epoxy hull, depending
              Steve,
              For an epoxy hull, depending on the type of paint you have on it, I would use lacquer thinner for hobby type paint. It can be purchased in a hardware store in small quantities.
              Wet a rag and rub the hull down. Depending on the type and thickness of the film, the paint will soften and wipe off. Work on small areas of the hull at a time.
              Brake fluid contains 80-85% solvent in the form of glycols -- that's why it works on paint too.
              Observe all health and safety precautions of course.
              • steve jensen
                • Nov 2006
                • 31
                Paint Remover
                This is a Thor boat; so now that I know, I can get busy, based on the great information...thanx for the tips fella's.
                Steve Jensen
                  Hey Steve - how did
                  Hey Steve - how did the paint removing project work out?
                  Tim
                  • steve jensen
                    • Nov 2006
                    • 31
                    Not really...right?
                    So-o-o I go out and get a new bottle of Super Heavy Duty brake fluid and then don latex gloves, a paper mask and open the bottle of brake fluid and using a brush spread it across one small section of the hull.
                    I wait 20 minutes and wipe it off.... Nothing!
                    I reapply it and wait 45 minutes and besides looking very shiny, nothing is happening. To be honest I expected to see bubbling, smoke(?) heat, light...something ...but I got 'N-gotz' from it.
                    So I wiped it off, then washed the hull with soap & water and put it away.
                    I woke up at 5am this morning; fearful that the fiberglass would be a melted puddle...I hustled down to the shop and...nothing; the hull looks exactly like it did before I started.
                    So where did I go wrong?
                    Thanks,
                      Don't know, unless you're really
                      Don't know, unless you're really out of luck and your boat has been painted with a two-pack product (which is essentially a resin), solvents won't do much against that stuff I'm afraid.
                      • hakkikt
                        • 246
                        You might have the wrong
                        You might have the wrong type of brake fluid.
                        There are different standards for brake fluid. DOT3 (quite old standard) is a killer, DOT4 works fine too for paint removal. DOT5 however is silicon-based and will not harm paint.
                        There is also DOT5.1, but I cannot comment on the paint removal properties of that.
                        Harald
                          Steve,
                          What type of paint is
                          Steve,
                          What type of paint is on the hull?
                          • steve jensen
                            • Nov 2006
                            • 31
                            Not sure of the type
                            Not sure of the type of paint - it was done by another modeler. I'm using DOT3 on it.
                            • jshag
                              • 41
                              The type of paint used
                              The type of paint used on the boat is Floquil Marine Colors paint. It is no longer made.
                              John
