Need info on Engel Piston pumps and conning towers
  • hampboats
    • Nov 2005
    • 208
    Does anyone have any information or diagrams covering the Engel piston arrangement (wiring from the pumps to the control device) and the conning tower control device? I need to know how to wire up the pumps to the control device and also figure out how the periscope device works
  • robert f.
    • 161
    Hi Dave,
    I have a scheme
    Hi Dave,
    I have a scheme for wiring the Engel piston tanks to the control device. Send me your e-mail address and I'll send you a scan.
    Rob
    • hampboats
      • Nov 2005
      • 208
      dhampton@ameritech.net
      I really appreciate the help!!!!
      • robert f.
        • 161
        Scans on the way!
        HTH
        Rob
        SC
        Scans on the way!
        HTH
        Rob
        SC member # 1832
        • hampboats
          • Nov 2005
          • 208
          Got them, thanks!!!!!!
          • jaschwink
            • Apr 2004
            • 56
            Dave,
            If I can be of
            Dave,
            If I can be of help, let me know. You may have seen my Engel Silversides in Carmel at one of the Indy Admirals Fun Runs.
            Jim Schwinkendorf
            • hampboats
              • Nov 2005
              • 208
              Engel
              Jim, I was trying to remember how you had your boat set up. Are you using WTCs for your piston tanks or do you use the clear bolt on tops that are typical with Engel subs.
                Dave,
                ....if it helps, my OTW
                Dave,
                ....if it helps, my OTW Seehund has a dive module that I built that uses an Engel piston for the ballast system. Here's photo of it:
                I'll be glad to answer any questions,
