Sub Soak
  • thesubdude
    • Nov 2026
    Sub Soak
    This Nikko sub got a little wet when I took it down to deep and the hull ruptured.
    After that, I had used it as a diorama prop while playing with the other. Thats the cause of the massive corrosion.
  • tennesseejim
    • 53
    Does this sub have the
    Does this sub have the magnetic coupling for the shaft?
    If so, can you take some pictures of how they did it.
    Thanks -
    • thesubdude
      Yes, it does. Here it
      Yes, it does. Here it is. There is a indent in the hull which the magnet fits around. See the diagram below.
      Edited By TheSubDude on 1159031206
