Water Pressure acting on an object
  • vanguard
    • 17
    How do you work out the water pressure acting on an object in stages from the surface to 10m underwater (Freshwater)?
    Edited By Vanguard on 1154613937
    Water pressure at 10 metres
    Water pressure at 10 metres is approximately 1 atmosphere, or 1 bar or 14.7psi.
    So it's roughly 1.5 psi per foot of water depth.
    • aeroengineer1
      • May 2005
      • 241
      The formula that you are
      The formula that you are looking for is rho*g*h = pressure
      rho = density of the liquid (kg/m^3 or slugs)
      g = gravitational constant (9.81m/s^2 or 32.2ft/s^2)
      h = height (must be in units of meters or feet)
      Do not ask me how the units cancel to give pressure, but this is the formula. It might also be noted that you can go from the midpoint of the object to determine the average pressure over the object. There will be little variation in a small model.
      Adam
      • Wheelerdealer
        • 315
        Pressure exerted on the sub
        Pressure exerted on the sub at the surface is 1atmosphere = 14.7psi =101.325 kilopascals. Every 10metres depth adds 1atm. Water pressure varies directly proportionally with depth, so at 1 metre down its 1.1atm, 2m down its 1.2atm, 3 m down its 1.3 atm and 10m its 2atm.
        So I guess the equation you are looking for is pressure(in atm) = 1 + depth(m)/10
        • vanguard
          • 17
          Thanks Guys!
          Thanks Guys!
          • Wheelerdealer
            • 315
            Just to clear it up
            Just to clear it up I was describing the total pressure acting on a sub at depth, the 1 atm form the air above pushing down on the water surface and the actual water pressure itself. The pressure exerted by the water itself is 1 atm (14.7psi). at 10m. The important bit is it varies proportionately.
            Have you got your sub yet?
            Edited By Wheelerdealer on 1154715752
            • vanguard
              • 17
              Thanks for all the info
              Thanks for all the info Guys.
              I have double checked Norbert Brueggen's book and his formula definately states pressure in Bar.
              Looks as if the error wasn't picked up in proof reading.
              For Wheeler Dealer.
              Yep. Got my sub last Friday.
