What is the right RPM for my boat - This can not be right
    • Nov 2026
    [color=#000000]Hi Subs,
    Im building a 1]http://fmx_5.tripod.com/132-3202_MVI.AVI[/url]
    (About 3,5 Mb)
    - And I would just like to know if this is normal, as I have not seen any RC Submarine with my setup.
    My setup are as follows]
    Kim,
    I tried getting to your
    Kim,
    I tried getting to your site but Tripod wouldn't allow it to download. Why are they so difficult?
    Mike Day SC#2502
      Hello Kim,
      A subjective interpretation of
      Hello Kim,
      A subjective interpretation of what is high, low, or correct RPM is somewhat irrelevant here. The model prop rpm will never match the 1 to 1 scale prototype, the pitch and surface area of course are radically different in size, and the density of the water (allowing for that we are discussing here fresh water instead of salt water) are a relative constant. Basically written, you can scale down everything but the water.
      Perhaps a better measure would be to find out (with your 3 to 1 gear [or belt]) ratio what amperage does your Graupner motor draw? A 3 to 1 ratio sounds correct here. Take a amp meter and test what the motor draws while the propellor is immersed in water. The stern end in a swimming pool or bath tub. Considering the size of a 1/96 Ohio, then you better consider a pool!
      The less draw, the cooler this motor works (the motor will get warm anyway) and the longer the running time will be from the same given battery charge. A large motor, like 1 to 2 amps might be acceptable for a 550 Graupner, lower the better. Careful alignment relationship of the motor, shaft, water tight seals, and bearings can effect this. It varies much, if it was a beautiful Maxon motor, I would be concerned about 1 to 2 amps being maybe too high. So it depends. Graupner motors are fine for the price, though I am sure everyone has their favorites.
      Build her good and straight forward water tight first, then refine her later as you grow in experience as to what is important and what is not. Try not to succumb to analysis paralysis. It is very easy to do, I have! Hope this helps.
      Steve Reichmuth
        Hi Steve,
        Im not trying to
        Hi Steve,
        Im not trying to scale everything down, but I realy thing that the screw will cavitate in the water - Its rotating faster than my kitchen blender (-]ftp://temp:temp@80.162.119.164/prop_prerun.avi[/url]
        My motor might be a johnson 550. and I can tell you that it draws about 4-5 Amps on my desk above water!!
        You say that graupner motors are the one to go for... Ill have a look at it.
        Thanks
        Kim Mortensen
          Hi All,
          Well I have split
          Hi All,
          Well I have split apart one of those handu car tire compressors, and removed the motor, and I found that it was a much better RPM and power consumption, only 0.9 Amp in free run at 12V.
          I mounted it in my sub, and powered it up, and it now had about 4 amps when fairly loaded (by hand). And I thing the water will load it that much, so Now Im happy about the speed of the prop.
          I Thing the other motors I used was not for 12 V... No wonder it was on the breach of taking off from my desk...
          (Anyway, if anyone would like the AVI, please email, As I cant seem to get the downloading to work..)
          Best regards
          Kim Mortensen
          • carcharadon
            • 301
            Kim, just wanted to toss
            Kim, just wanted to toss out a couple of ideas for what it's worth. I would guess that as a rough approximation of the motor RPM versus motor heat, you could run the prop in water and hold the motor. If the motor gets too hot to hold I would take this to mean that the RPM is too high for the prop pitch. Also if you've gone to the trouble to take apart an air compressor motor you might want to consider the motor in a bilge pump. You could probably remove the bilge pump impeller and somehow replace it with the shaft to turn the prop. Although I haven't done this I would think that a bilge pump motor would be more suitable than any air compressor motor. Also it's designed to run in water so your motor could be outside of the watertight chamber.
              Is it possible to provide
              [color=#000000]Is it possible to provide me with a picture of such a blich pump, and possibly where to get it (-]
                I know that this has
                I know that this has been beaten over the head before, but you may wish to consider the cooling fan from a car's radiator.
                I'm using such a motor. It's about 3" long, 2.5" diameter and has a 5/16" shaft. My initial test revealed current draw at 1A free running, 4A under full load (that's as much friction as I could apply with my bare hands... I'd imagine that propelling my sub will require far less torque), and 14A fully stalled. This little sucker will virtually screw off the lug nuts from your car! My cost]The Nautilus Drydocks[/url]. Just click on the "electronics" button at the top of the page and scroll down to see the motor (pic is on the right hand side).
                If you have any questions, I'd be happy to help out.
                • carcharadon
                  • 301
                  Kim, any marina should carry
                  Kim, any marina should carry a variety of bildge pumps
                  try
                  Explore Johnson Pump technologies from ITT Flow Technologies, including centrifugal, gear, lobe and screw pumps engineered to deliver reliable fluid handling, process efficiency and operational performance across industrial applications.
                  or
                  http://www.rule-industries.com/
                    The Radiator fan motor seems
                    The Radiator fan motor seems to be right, Ill look at the option as soon as I go to the scrap heap.
                    Thanks for the help...
