How to make cheaps seals ! - For the do it yourself guys !
  • thierryc
    • 162
    A friend of mine showed how to make make water tight seals for pushrods coming out of the WTC and that is so easy and cheap that I thought I should share it here.
    First you need a Pneumatic fitting, available at any car store, diameter matching the diameter rod, here 1/8
    Edited By ThierryC on 1059701724
  • thierryc
    • 162
    Open it and remove the
    Open it and remove the compression fitting inside
    Edited By ThierryC on 1059701769
    • thierryc
      • 162
      Then you need to carefully
      Then you need to carefully bore the inside of the fitting to the diameter needed, here 1/8. A hand drill works, a drillpress is better.
      Edited By ThierryC on 1059701800
      • thierryc
        • 162
        Once the inside is nice
        Once the inside is nice and smooth, fill up the fitting with lithium grease
        Edited By ThierryC on 1059701831
        • thierryc
          • 162
          Then put a 1/8 oring
          Then put a 1/8 oring on the opening
          Edited By ThierryC on 1059701856
          • thierryc
            • 162
            Finally screw back the top
            Finally screw back the top of the fitting in place, make sure to squeeze the oring tight but not too tight
            And Voila ]http://sub-systems.dyndns.org/subcom-on/forum/seals/dcp05733.jpg[/img]
            Total cost $12CDN for 5 of the 1/8 (including oring) and 2 of the 3/16 (including oring
            Edited By ThierryC on 1059701898
