Electric Motors as Generators? - Could this work?
  • captain nemo12
    • Sep 2003
    • 279
    [color=#000000]Hi guys,
    I was thinking about a way of generating small amounts electricity to power small light bulbs or LEDs located on a model sub's conning-tower, and I thought about this]
  • aeroengineer1
    • May 2005
    • 241
    Perhaps the voltage or amperage
    Perhaps the voltage or amperage supplied were not enough. This method though is not the best way to do this. You are taking electricity and then transferring it to the main motor to do work. Some of this work is used to turn the generator (which is less than a 100% energy conversion) and then you transfer it to you bulb. You are adding 2 elements that are both going to reduce the efficiency of the transfer of energy to your bulb. Basically it amounts to a lower run time.
    Adam
    • himszy
      • Nov 2004
      • 282
      I'm not sure on this,
      I'm not sure on this, so please correct me if I'm wrong. But I believe a dc motor is an ac generator.
      Michael
        Nope. A dc motor can
        Nope. A dc motor can be used as a dc generator.
          Yes the reason you are
          Yes the reason you are not getting anything is due to losses. If you stick a mulitimeter on it you detect a current. I remember a school experiment where we turned a motor by hand to light a bulb
