Plans
    Plans
    Hi all im new to this site and i need some help/information already.
    Im looking for plans of the seaview from voyage to the bottom of the sea.
    preferably the Tv series with the 4 observation window's...
    Any help or links gratefully received.
    Also does anyone know the overall dimension's of the engel piston tank's? Either the 500ml or the 750ml
    Thanks and best regards
    Adz
  • silent runner
    • Jun 2005
    • 188
    Welcome aboard!
    All Engel
    Welcome aboard!
    All Engel tanks are the same diameter of 2.95", however you should allow an extra 3/8" for the drive motor. Maximum length of the 500ml tank is 12 7/8" Maximum length of the 750ml is 18 5/16". Maximum length is in submerged condition as you must allow room for the piston rod to travel from surface mode to full dive mode.
    Hopefully, another here can shed some light on plans for the Seaview.
    Mike
      Thanks very much for the
      Thanks very much for the information mike.
      Just wondering what size of tanks to use?
      My friend want's to build a seaview to the same size of the old deboer hull/ 80" or 2320mm.
      Im looking into building either A british S-class or T-class.
      Even had a look at the Disney-nautilus.
      best regards adam
