Balast info need???
  • mar7ck
    • 198
    Balast info need???
    I need a substitute for propel in my sub. propel stains my tube.
    Does anyone have any sugestions???
    Mar7ck
    The Small Sub Guy
    Sounds like a personal problem,
    Sounds like a personal problem, Mark
    But seriously folks, Mike Dory got me to switch to "Super Duster 134 REFILLS" click the link below to go to one of the supply houses that sell it.
    Super Duster 134 REFILLs
    Note - be sure to get the REFILLs. They come with the threaded fitting that fit the standard Propel adapter. If you buy a case of ten cans they are $7.45 per 10 oz can so its cheaper than Propel and it is zero Residue - no greasy junk left in your WTC.
    The Material Safety Data Sheet for the product lists it as having ZERO Flammability - On the other hand, Propel has Butane - the stuff in cig lighters. The main danger for Super Duster is frostbite - especially if you get it in your eyes (talk about an "icy stare"!) ]http://www.rpelectronics.com/Data/402AR.JPG[/img]
    Edited By TMSmalley on 1125057924
    • chips
      • 494
      Are you using the cheap
      Are you using the cheap Testor's airbrush propellant or the more expensive Badger Propel? Testor's has an additional chemical to prevent kids from "huffing" it - smells like raw onions. The Badger Propel has less impurities than the Testors brand.
      Edited By chips on 1125072664
        The MSDS (Material Safety Data
        The MSDS (Material Safety Data Sheet) for Badger Propel states]This product is considered to be extremely flammable [/b]as described in 16CFR 1500.45.Flammable Limits - % Volume In Air (Propellant)]MSDS for Badger Propel[/url]
        The MSDS for Super Duster 134 Plus is at]http://www.cir.com/mgchemicals/msds/msds_402a-aerosol.html[/url]
          I recommend a compressor system,
          I recommend a compressor system, pump system, piston system or indeed just about anything other than a propel system!!
          'Who isn't a big fan of gas ballast systems'
          • mar7ck
            • 198
            Thanx everyone.
            Mar7ck
            The Small Sub Guy
            Thanx everyone.
            Mar7ck
            The Small Sub Guy
