Scale Speed - How to Calculate?
  • ramius-ii
    • 393
    If you know the speed of your sub in actual MPH (Miles Per Hour) how do you convert to the speed of a scale model?
    Ed
  • rcher
    • Jul 2004
    • 39
    If you know the scale
    If you know the scale of your submarine ie 1/72 then you would mulltiply the speed by 72.
    For example, if the speed of your sub is 5 knots, then 5 x 72 = 360 knots.
    • seanletsflytwo
      • Aug 2004
      • 6
      also, if you wanted to
      also, if you wanted to go backwards, from realto scale, then you divide
        Correction, you need to divide
        Correction, you need to divide by the square route of the scale.
        i.e. in the case of my Vanguard, which is at 1/100 scale and the fullsize speed of 25 knots
        25/10= 2.5 knots
        Add in a model factor of between 1.5 to 2.0, which will give a model speed of between 3.75-5 knots.
        This is the speed required for realistic wave formation/wake around the model and responsive control surfaces equivalent to the fullsize counterpart.
        More information on this is featured in the book 'Model Submarine Technology' by Norbert Bruggen.
        Models may get smaller but water molecules don't!
        Edited By Sub culture on 1093467000
        • koeze
          • May 2003
          • 204
          Sub Culture is right.
          Model Speed
          Model Speed = Square root Original Speed
          This is a model rule used in Hydrodynamic Calcalutions ie towtesting model ships.
          EJK
          • ramius-ii
            • 393
            Thanks Guys! http://www.subcommittee.com/forum/icon_smile.gif
            The
            Thanks Guys!
            The only question left is what is the "Model factor"?
            Best, Ed
              The model factor is merely
              The model factor is merely a number, without any units, inserted into the equation to account for the inefficiency of small scale props and control surfaces.
              Whether you go on the smaller side of that number e.g 1.5 or larger- 2.0 would depend on how you feel the boat is performing in the wet stuff. Some designs ape their fullsize counterparts better than others- thus requiring a larger or smaller model factor.
              You really ought to grab yourself a copy of Norberts book if you are interested in this kind of thing.
              There is a lot more to this subject than can be explained in a few lines on a messageboard.
              • ramius-ii
                • 393
                Thanks Andy http://www.subcommittee.com/forum/icon_smile.gif The book
                Thanks Andy The book does not seem to be avaliable which is why all the Q & A's.
                Best, Ed
                  Best, Ed
                  http://www.amazon.co.uk/exec....4747035
                  The Amazon UK site seem to have some!
                  Also these guys seem to have some too-
                  With over 50 years experience, Sussex Model Centre are a scale model and hobby shop based in Worthing.
                  Edited By Sub culture on 1093624879
