How can you make a Tee valve?
  • captain nemo12
    • Sep 2003
    • 279
    Hi all,
    I still needed a sort of valve that goes between the pump and the ballast tank of my Kilo. I was thinking of fabricating my own tee-valve, can anyone who has done this step tell me how?
    Thanks!
  • ramius-ii
    • 393
    Hi Captain]www.Clippard.com are probably good
    Hi Captain]www.Clippard.com[/url] are probably good starts.
    Best, Ed
    • dietzer
      • 255
      Try SubTech (www.rcboats.com). Skip sells
      Try SubTech (www.rcboats.com). Skip sells a Ballast System Tee Valve that might do the trick for you.
      Carl
        Hi,
        Are you pumping into a
        Hi,
        Are you pumping into a sealed tank, or a vented tank?
        If it's the former, then all you need is a roller mounted on the servo arm and mount the servo in such a way that it will pinch the hose closed when the servo is at neutral.
        You need to use a soft silicone hosing for this to work effectively.
        It's the system used by Sheerline/Eden for their boats.
