Online machine shop
  • novagator
    • 820
    Online machine shop
    http://www.emachineshop.com/
    for those that don't have the machines or skill, you can submit what you need, and they will make it for you.
  • interpol
    • Mar 2004
    • 47
    This is very cool. Now
    This is very cool. Now I can have those home-made projects seem like they were actually made by a professional!
    • fx models
      • 166
      Hi,
      I dont know how within
      Hi,
      I dont know how within reach your homemade projects are going to be. I priced out 5" square, .25" steel plate with three holes in it for fun and asked for it to be laser cut or wire edm'd... The pricing was over $5k for the wire edm... Laser was $1200.
      I will go back and try aluminum but steel is what I wanted.
      I am SURE though that I have not paid full enough attention to material type versus machine to make it a proper choice, so perhaps all I am saying is that machine versus material is an important parameter!!!
      Marc
      • interpol
        • Mar 2004
        • 47
        Wow, I was actually making
        Wow, I was actually making titanium stuff and it didn't cost that much.
        Cutting 1/4" steel with a laser would require a pretty hefty laser, so I could imagine why it would be so expensive. Try changing the machining option to regular milling or even water jet.
        • fx models
          • 166
          Hi,
          Went back and checked my
          Hi,
          Went back and checked my settings... I had a QUANTITY of 100 set! Whoops!!!
          Ok its back on my favorites....
          Marc
          • novagator
            • 820
            Hi,
            Hi,
            Marc
            oops!
            • ramius-ii
              • 393
              Thanks Novigator, it looks like
              Thanks Novigator, it looks like their sister company pad2pad, is a good find. As for the emachine software, it need work. I've been doing Autocad for years and I took a drawing exported it from Acad to .dxf, imported it into their program and it was close, and missed lines as well as changed others! A straight line became some kind of angle, it considers a "hatch" pattern (commonly used to indicate a solid) as "too many lines" , etc. I sent them both the .dwg and .dxf files to figure out. It is a good find and much appreciated. I hope the conversion and compatability problems will be easy fixes. Of course, it could very well be something basic I did, too many hours of design work and you have no brain left!
              Best, Ed
