RX battery - Querie
  • david h
    • 199
    RX battery - Querie
    Dear all,
    Can i run a Reciever off a 6v 1.3 am Sealed lead acid battery?
    regards,
    david H
  • wheels
    • 129
    David...You can run your radio
    David...You can run your radio off of a 6 volt sealed lead acid battery. It will make the servos run faster and be a little stronger too. If this is the main battery for the model I would not recommend doing it because if the battery dies your radio dies too, and then you loose control. I have limped in with a low main battery, because my radio was fed off a secondary battery.
    • david h
      • 199
      Dear wheels,
      Thanks for that advice.
      Dear wheels,
      Thanks for that advice. It would just save me alot of time if I could simply use a lead acid battery then I would'nt have to open up the WTC all the time. I could hook up the lead and the reciever would come to life.
      So 6v won't fry the Reciever.
      I have some stuff on the Deep down Aussie site you may want to look at. I have a Yuushio, Akula and an L.A
      regards
      David Hughes.
