foam cutting
  • novagator
    • 820
    foam cutting
    What is the best method to cutting foam for installation in the sub. I got a sheet of the insulation foam from Home Depot (bad part is its pink. Darn, really wanted blue), but I want it to look good in the sub.
    I use a variety of
    [color=#000000]I use a variety of means]
    • mike byers
      • May 2003
      • 103
      You could try this, and
      You could try this, and maybe modify it to the size that you need.
      Aero-Quest
        That's a hot wire, which
        That's a hot wire, which you can easily knock up yourself for next to nothing (nothing at all, if you're a master scavenger and skinflint like me!)
        You need to use nichrome wire (often used in the heating elements of electric fires) and a low voltage DC supply.
        More info-
        http://www.hhhh.org/~joeboy....er.html
        Hotwire cutting is the best way to fashion foam, because it doesn't make any mess. However the foam does gas off as it melts so cut in a well ventilated area, and you'll be fine.
        • novagator
          • 820
          Thanks Guys, I went and
          Thanks Guys, I went and got a cheap one from Michaels. Hopefully it will work.
