ok, so making the sub turned out the be the easy part. painting the sub seems to be the hardest part so far. nothing is working. so here's the deal. i have my hull already painted in red and black Testors spray paint. now i need some sort of clear coat. where do i go from here and what do i use? i tried 2 different Krylon acylic clear coats (doesn't seem to work, but could it be the humid air? the only wait i could get a smooth finish was by spraying the hull 3 inches away. if i sprayed from about 12 inches away, it just left a "dusty" looking finish, like i said, could it be b/c of the moisture in the air?), one by Dupli-Color (appears to react with the paint so that it makes little cracks in the paint finish), and the Testors Dullcote and Flat Lacquer. luckily i painted a few extra hull peices to test the paints and clear coat on. here's what i did. i took my extra hull peice and painted it with Testors Flat Black. I then gave it a few coats of Testors Flat Lacquer and let it dry for a few hours. i put it in a bucket of water for a few hours and of course i got white spots that i mentioned in an earlier post. then, i painted my REAL hull with the same Testors Flat Black, but waited a few days for the paint to dry, then i gave it 4 coats of Testors Dullcote. only this time i waited b/w 8-12 hours between clear coats and waited 21 hours after the last coat before puting the hull in the water for about 1.5 hours. well, guess what? i got white spots again, although not as many. so here's my question. did i do something wrong while painting on the Dullcote (such as not waiting long enough to dunk it in the water) or do i just need to find another clear coat? if it's the latter, what clear coat could i use that is flat (but i'll take semi-glossy if i have to) and won't screw up Testors paint? i know it's recommended that the clear coat, whatever the type, is the same BRAND as the colored paint, but obviously it's too late for me; i don't think i can scrape off all the red and black paint already on the hull, especially around the fins.
this is so frustrating.
p.s. if you can't answer my questions, can u at least tell me how you guys paint your hulls? at least i'll learn for future reference
