servo questions - voltages
  • mike d
    • 2
    Hey SC members.
    I using three 1/4 scale servos (futaba) in a large sub.
    Im not using a typical batery Im using a 12v deep
    cycle marine batery. i have a transformer to bump
    down to 6v. for the r/c stuff.
    Its one of those car types with differant
    voltage outputs. I have its + wired directly to a 3 amp
    fuse. then it connects to the receiver. Gound is directly
    connected to neg on the batery via a .01uf and 10uf @ 6v
    caps. (to take out electrical noise) when i put a meter on
    the + get a reading of 6.35v. Going to the reciver.
    Is this bad? I have been running this setup for 5 years
    with not many problems but need to know...is this bad?
    dose voltage have anything to do with torque?
    what is the norm. for operating servos (volts and amps)
    dose it matter if you are running a little higher?
    Also what is the usuall voltage and amps provided in those
    gell cells i see people using in r/c stuff?
    one more...my servo leads are very very long....6 feet to my rudder one...is the lenth of the leads something to worry about?
    As i said befor...i havent experienced many problems over the years but i am now installing a pic microcontroller to make the sub atomomus...the controller has outputs for servos and also has a external supply hookup for just the servos. (i guess this is so you dont need to use the voltages thru the controller. )
    so if i use the external supply, can i hook it up to the transformer Im using now with the currents its supplying now?
    Or should i do something else? One thing to remember , i would like to use the 12v batery (bumping it down to 6v) for all of the
    r/c stuff. I do not wish to add other bateries for the r/c stuff.
    any feedback or comments would be great to hear from you guys on this subject.
    Michael
  • rcade
    • 21
    Most 12 volt batteries when
    Most 12 volt batteries when completely charged actulaly put out 12-14 volts. If you are stepping down the voltage with a BEC it will put out more than 6 volts if supplied more than 12 volts.
    I run a 7.2 volt battery in my helicopter and it does boost the torq and speed a little. I have had no problems in using higher voltages and I have been doing this for 8-10 years. I use Futaba and JR systems. Keep in mind that JR transmitters use the black wire as positive. The receiver uses red as positive. Don't know why.
      Hi Mike]
      [color=#000000]Hi Mike]
