Discussion, " is CA Glue Waterproof enough?.. "
  • Wax Savage
    • Jun 2025
    • 26
    A popular method to bridge gaps is to saturate baking soda with thin CA glue.
    Fact: Baking soda dissolves readily into a solution when in contact with water.
    The argument...
    This cannot be a good thing for joints in a boat hull. What about the CA glue used to stiffen baking soda joint? Doesn’t it seal off the baking soda from contact with water?
    I put the question on the internet. Here is the answer..
    May 2, 2023 David Codillero, Starbond Glue
    Once cured, our CA glues are definitely water-resistant, but if submerged and constantly exposed to water, the water will act as a solvent and degrade the CA glue.
    For outdoor applications where exposure to a high level of humidity is expected, our KEG-500 Flexible Medium-Thick CA glue is recommended. This adhesive is four times stronger than our standard CA glue, and has a higher resistance to heat, humidity, and natural weathering.
    Okay, CA is water-resistant. Still, not a satisfactory answer for a joint immersed in water.
    Armed with this information, I prefer, whenever possible, to use a mixture of phenolic micro-balloons mixed into slow setting two-part epoxy. This is as waterproof as it gets. When I use the baking soda/CA glue method, I seal off the joint by painting over the joint with slow-set epoxy or, two-part epoxy paint. For soda/CA joints that will be seen on the finished model, I have painted the joint with slow-set epoxy thinned 60/40 with acetone with good results. Remember to coat both sides of the joint.
    Maybe this is overkill but, I am just anal enough to try and put the odds of long term joint integrity in my favor.
    As gluing and adhesion is quite basic and vitally important to model building, p
    lease add your experience, observations and opinions to this thread.
