O ring education
  • secrtwpn1
    • 269
    O ring education
    I need some help in the "o" ring department. In the past , I have ordered several o rings from the O ring store. They were too hard. So, what am I looking for when I need a softer O ring? The site has a zillion different types.....
    Farlan Clutters
  • tommydeen
    • 327
    Does it have specs of the shore hardness of the o rings. I would call the company up and ask
    • secrtwpn1
      • 269
      What is shore hardness???
      • aeroengineer1
        • May 2005
        • 241
        Mcmaster has a pretty good range of o-rings that you can select from. A typical Buna N o-ring is a 70 durometer (around the hardness of a car tire). You can get soft Buna N o-rings that are a 50 durometer (a little harder than a pencil eraser). For water with chlorine in it, I like to use viton for sealing as it has excellent compatibility with chlorine. You can find them in a 60 durometer here at mcmaster. https://www.mcmaster.com/#o-rings/=1b4t77x
        • tommydeen
          • 327
          • tommydeen
            • 327
            You also want to read through parts of this
            Manual
            https://www.parker.com/literature/OR...g_Handbook.pdf
