Depending on when the photo was taken, there was a time when the US Navy did everything possible to essentially deny that the Seawolf class would use a propulsor.....including having models built with the standard LA-class like prop.
As I understand the USS Jimmy Carter was modified to the extent of having a 100 foot section added to it. The model does not seem to reflect this addition. The screw seems to be some generic five-bladed screw, although showing a skew-back character.
The SN-21 class is 350 feet in overall length. This would be the USS Seawolf and USS Connecticut. The USS Jimmy Carter is 453 feet in overall length.
I also found the/a source of the photo...it was taken on April 28, 1998 during the naming ceremony for the sub. ...so the lack of a propulser probably makes sense. (Cold War still more-or-less going on, etc.)
The launch date is currently scheduled for June 4, 2004. Jimmy and family are expected to be on hand.
Actually, the 353' dimension is misinformation. The SSN21 is 361' long. The 353' dimension they advertise in the public literature is the dimension from the forward perpendicular to the center of the rotor stack. There is still quite a bit sticking out behind this!
