Scratchbuilding a hull without decent plans - looking for guidance from the experts
  • ninjrk
    • 47
    I'm hoping that some of the experts on the board can give me some guidance. I've finally amassed about all of the reference on the Japanese Sen-Taka class subs as I'm likely to get and want to start planiing to build one. However, there are really no decent cross-sections out there that accurately capture the shape of the boat. I'm going to need to basically free sculpt the hull until it looks right. I have never scratchbuilt a hull before where I didn't have adequate plans, so I'm a little lost here. The closest I've come involved a rather cumbersome process where I sculpted a half-fuselage, then cut it into sections to use the sections as templates to make cross-sections. I then used those to build a typical frame and skinned it. There must be a better way to do this and I'm hoping that someone can tell me what it is.
    I need to have a I201 sailing with a Type XXI, I just need it!
    Thanks for any and all help,
  • boatbuilder1
    • 386
    I am going thru the
    I am going thru the same issue with the halibut but I went another route I drew up the cross sections using photos and other resources I drew up the plan view of thed eck and that at least gave me the top width of the cross sections
    now I plan to cut the stations( bulkheads) out of foam with ot wire cutting and epoxy them together and sand to shape then have a professional grp mold made
    hope this helps
    ca
    • david h
      • 199
      G'day,
      I have done the same
      G'day,
      I have done the same thing with my chinese Navy Type 092 "Xia" class Ballistic missile boat.
      There are only about 12 photo's of this boat released in the west. I could only work off these pictures.
      I had to draw up drawings that i made from these pictures and speculate below the waterline.
      I tried to gauge sizes from the Sailors on the deck and estimate how bit i thought the sial in particular would be from this.
      regards,
      David h.
