Nitro Stan 9001 - where can I get it at?
  • novagator
    • 820
    Anyplace online to buy this?
    go to any automotive supply
    go to any automotive supply place (NAPA, etc.) and get the red lacquer body putty...same thing basically. wet sand for best results.
    • novagator
      • 820
      thanks, i will check out
      thanks, i will check out Napa.
      • wayne frey
        • 925
        I am using Nitro Stan
        I am using Nitro Stan on my Alfa build. I got it from a store that sells bodywork materials.Look in the yellow pages under automotive and see if you have one local. It has a good result.
        Matt also recoomended Plasticote # T-235 Lacquer primer which I find easily at Pep Boys or other automotive stores.That stuff works great! It shows imperfections,dries quickly, and looks good. I give that a big thumbs up to use as you build.
        • novagator
          • 820
          I will have to check out my local pep boys for the primer.
          • novagator
            • 820
            I got a tube of
            I got a tube of Lacquer glazing putty "red oxide" from napa. Is this the right stuff? It says it is used for filling sand scratchs, file marks and other imperfection, and to apply it to the primer coat.
              that's the stuff. it will
              that's the stuff. it will do the job. remember to wet sand it for final finishing.
